Kucher v1.0 is released for Windows and GNU/Linux
28 August, 2019
Pavel Kirienko
CEO & CTO
Kucher v1.0 is finally released and available for download. Here are the direct download links:
- GNU/Linux: https://files.zubax.com/products/com.zubax.kucher/1.0.0/linux-x86_64/Kucher
- Windows: https://files.zubax.com/products/com.zubax.kucher/1.0.0/windows-10_64/Kucher.exe (designed to work with Windows 10, compatibility with older releases is possible but not guaranteed)
The executables are portable and require no installation, just download and run. You may need to set up your USB connection as described here: USB - Knowledge Base - Zubax Knowledge Base
You can still run the application from sources as well, of course:
