Telega v0.2 is released
01 February, 2019
Pavel Kirienko
CEO & CTO
Telega firmware v0.2 is now available for download from the file server. The firmware can be updated via CAN using the UAVCAN GUI Tool.
Changes from v0.1:
- Improved stability, especially during rapid acceleration and deceleration.
- Field weakening (flux weakening); please contact us for setup instructions – official documentation will be released later.
- Fixed the power-up issue where the device would refuse to boot unless the power supply voltage slope is steep enough.
- RPM control loop stability improvements.
- Motor characterization improvements.
- Faster boot-up – approx. 200 milliseconds from power on to ready to run.
- Faster and more robust spin-up process.
- Motor self-test at power-up is not performed by default; can be enabled via
ctl.pwron_slftst. - Selectable spool-down policy: either controlled braking (default) or immediate power stage deactivation (set
ctl.hard_stop). - Parameter renamings:
m.spup_current_l→m.spup_curr_begn -
m.spup_current_h→m.spup_curr_end -
m.phi_milliweber→m.flux_linkage(change of units: milliweber → weber) -
m.rs_ohm→m.resistance -
m.ld_microhenry→m.induct_direct(change of units: microhenry → henry) -
m.lq_microhenry→m.induct_quad(change of units: microhenry → henry) -
m.eangvel_rampup→m.eangvel_accel -
m.eangvel_rampdn→m.eangvel_decel
Read the updated setup guide: Quick start guide for Myxa v0.1.
